Just wondering if anyone knows the output amps I should expect from a TEF dyno at idle or 50% throttle?
I've stripped and cleaned the dyno and it will deliver an output when attached to an electric drill at speed but less so when I try to replicate an idle speed.
I've attached the dyno back to the engine with the intention of hooking up an volt/amp tester but need to know what level of amps to expect.
Jut trying to work through all possible tests before replacing the whole unit...
Any help would be great.....
