Can anyone tell me what the correct tire pressure is for a 11.2 x 24 rear tractor tire on a Ford 2000 is, it is not listed in the owners manual. Thanks Paul
depends on what you have for weight on the tractor. general rule is air pressure 1 to 2 lbs more than the cross section of tire. 11.2 === 12 or 13lbs, add one lb of air pressure for every hundred lbs of weight on rear tires==i e wheel weights, mounted equipment.
