1 - 1 of 1 Posts
I have a 1957ish John Deere 60 that is stuck in reverse.Ive pulled the top cover off the transmission and found that all the shift fork assembly's slide properly except for the one towards the rear of the tractor,which is the reverse,first and third gear shifter shaft.Can't tell if it is stuck on the shifter shaft or on the splined shaft down below.It might be the detent and ball assembly that is worn out.Has anyone got any suggestions?
1 - 1 of 1 Posts
