I've got my '47 B up and running, and am ready to install a battery. The box looks to fit a battery of 12"x8"x8"tall (top of posts). What's recommended? Thanks
Gennys don't care about polarity. The only thing that changes is the ammeter, starter, and battery wiring. Although, 99% of two cylinders with a genny are positive ground.Lovesthedrive said:There are 12 volt generators. Just be mindful that most generators were positive ground.
Correct. I said starter because the wire to the battery matters. The internals of the starter don't care.Lovesthedrive said:Satarters dont care about polarity. Turn same direction no matter the polarity.
Onlything that does care is if you use a GM alternator. You will kill the diode tree with a positive ground. Alternators require negative ground, no rewiring necessary. Only thing you might consider is a balast resistor for your points.
