Wiring an H with a mag. to 12 volt. The wire that runs from the Alt. pin 1 to the Amp. gauge, on a Dist. Ing. runs to a warning light to the switch and then to the amp gauge. I'm thinking if I run it to a warning light to the amp gauge it will stay on after I ground out the mag. I can't run it thru the switch, and if I run it straight to the gauge will that keep battery power to the Alt and cause problems. I don't have a wiring diagram for 12v with a mag so I'm using both12v w/dist. and mag 6v.....mike
